Roof Bar Seals
Old Apr 6, 2022 | 06:18 PM
RizzleKicks's Avatar
Default Roof Bar Seals
I've been asked by my elderly neighbour , who owns a 2004 D2 and not very computer literate to put up a post on his behalf.
He has the G4 Roof Bars and has noticed the roof lining is wet, a closer inspection confirmed the roof bar gaskets are the issue.
Has called the local Stealers , who say the Roof Bar gaskets are obsolete and would not give out part numbers. Can anyone help auld Hamish with part numbers ?
There was also the possibility of using a sealant adhesive around the base of the bars and then setting the bars in place , what is the best adhesive to use for this and one that won't damage the paintwork , can anyone recommend sealant?
Been advised no TigerSeal as its hellish to remove if required to do so.
TIA
RizzleKicks
Old Apr 6, 2022 | 07:06 PM
Richard Gallant's Avatar
I used clear silicone, if use a soft plastic spatula you can lift the seal and get underneath - yes it is painful. Then you need to get around the roof bar where it meets the seal figure a couple of hours.
Also if there holes in the roof bar for cross rails get a bolt that fits and seal it really well
Mine has not leaked since I did that
Old Apr 7, 2022 | 12:14 AM
👍🏽 Richard , now just a general purpose silicon will do the job ?
Old Apr 7, 2022 | 12:23 AM
@RizzleKicks Yup standard clear is all I used, you could use black if you can find it but it was easier to use clear.
Old Apr 7, 2022 | 08:09 AM
cvhyatt's Avatar
I took the headliner down and used it as an opportunity to fix leaks with the sunroofs and the bars. I used flex seal inside and ouside. I also reconditioned the seals with some silicone.
Old Apr 8, 2022 | 09:51 AM
The_OGCJR's Avatar
I’ve also seen people remove the bars and run without them. There is a plug that goes over the holes. I don’t know the part number though
Old Apr 8, 2022 | 09:59 AM
adalton's Avatar
The part number is M0338-001. They are the same size as the holes left behind from removing the roof bars. They fit right in but it is good to apply a small amount of silicone around the seal.
Old Apr 11, 2022 | 10:59 PM
nashvegas's Avatar
The 2004-only roof bar seals are pretty easy to seal with black silicone / sealant. Just remove the bars (which requires removing headliner, sorry ... ! ... and seal the holes. Much easier to seal than the silly foam ones on the earlier models that absorb water.
Just don't use too much
alps.defender
Apr 13, 2024 08:49 PM
Paul Deatherage
Apr 11, 2021 12:24 PM
mr. choodles
May 24, 2020 07:44 PM
Saturnine
Jan 11, 2019 03:06 AM
NiteTrain
Apr 22, 2009 08:07 PM
