rotational clunking
Hey Disco mike, I need your Knowledge I have a 1995 disco, It has new pads and rotors, new shocks. since replacing I have devolped a rotational clunking noise in the rear. I have checked front and rear pumkins, axles, driveshafts, t-case I just can pin it down... Do you have any kind of sugestions you have would be gratefull...
Hello Disco Mike,
Hope you are still on this site. I'm getting a similar rotational clunk also after changing brakes and rotors. Looks like bushings are worn in the front end, but don't see any obvious wear marks on those components.
Odd that it happened right after the brake work. Could it be an improperly installed bearing seal? CV joint? Diff fluid looks good.
tobob1
10-03-2006 11:37 AM
MaxColee
06-25-2006 09:49 PM
