rotational clunking
Old May 8, 2007 | 09:54 PM
bangbang's Avatar
5th Gear
Default rotational clunking
Hey Disco mike, I need your Knowledge I have a 1995 disco, It has new pads and rotors, new shocks. since replacing I have devolped a rotational clunking noise in the rear. I have checked front and rear pumkins, axles, driveshafts, t-case I just can pin it down... Do you have any kind of sugestions you have would be gratefull...
Old May 9, 2007 | 07:27 AM
Default RE: rotational clunking
When do you hear it most, does it go away if you tap the brakes, have you lubed and inspected the u-joints? How many miles on the truck, have you drained your rear diff to check for metal in the oil?
Mike
Old Oct 13, 2014 | 10:08 PM
RoverMark's Avatar
Default Same Rotational Clunk
Hello Disco Mike,
Hope you are still on this site. I'm getting a similar rotational clunk also after changing brakes and rotors. Looks like bushings are worn in the front end, but don't see any obvious wear marks on those components.
Odd that it happened right after the brake work. Could it be an improperly installed bearing seal? CV joint? Diff fluid looks good.
moorebl
Aug 25, 2021 08:16 AM
Trooper107
Jun 25, 2010 06:12 AM
Money Pit
Freelander
Nov 2, 2008 10:45 AM
tobob1
Oct 3, 2006 11:37 AM
MaxColee
Jun 25, 2006 09:49 PM
