Rough idle after oil change
Old Nov 12, 2013 | 10:37 PM
bballjames's Avatar
Default Rough idle after oil change
Hey guys, I am getting a rough idle after an oil change. Used Rotella as normal. I put in just over 7 quarts as normal. Now she runs a little rough. No codes or CEL. Accelerates great and otherwise drives fine. And after it warms up it idles fine. Only when first cranked cold does it idle rough. Weird right? Any ideas?
Old Nov 13, 2013 | 06:21 AM
coors's Avatar
7 quarts? I run a Mobil 1-301 extra capacity filter and can only get 6 maybe 6.3 quarts in there. Probably not your issue. What weight oil? Heavy weight? Is it cold where you are?
I'm battling a rough idle issue also am stumped as well.
Old Nov 13, 2013 | 07:49 AM
bballjames's Avatar
Hey coors, ya 7 was a mistype. I am running 15w40 as I always do. It idles rough and really feels like it wants to die. Almost like when I did the seafoam induction cleaning... I just have no idea what could causing it.
Old Nov 13, 2013 | 09:55 AM
coors's Avatar
My truck did not start this morning. I think it may be a crank position sensor.
Old Nov 14, 2013 | 09:32 AM
bballjames's Avatar
Good luck on getting your truck back running. My rough idle has gone away, so I'm wondering if some water or something was causing it.
dillhole
Feb 20, 2020 02:30 PM
KGN96discoSE7
Sep 23, 2017 07:23 AM
bballjames
Jul 8, 2012 11:21 AM
collin Barrows
Aug 28, 2011 07:13 AM
treant985
Dec 27, 2010 02:51 PM
