rough idle at startup
Old Mar 17, 2010 | 09:09 PM
starcraft1's Avatar
Default rough idle at startup
Hey all,
The last few days when I turn on my truck I get a pretty rough idle. It doesn't come close to shutting off or anything it just will shake around for a bit. If I let her warm up for a little while (say a minute or so) she will go back to normal, and then everything is okay after that. I am not getting any codes so I don't really have anything to go off of. One thing is is that I have a coolant leak somewhere but it is not going into the oil. Its leaking out of the front of the engine somewhere (water pump perhaps). Anyway, any ideas on the idle situation. Thanks
Old Mar 17, 2010 | 09:20 PM
Possibly a weak fuel pump.
Could be bad plug wires.
Could be a dirty idle air control valve.
Dirty throttle body.
Dirty air filter.
Bad gas.
Wrong grade of gas.
To much ethanol in the gas.
Bad spark plugs.
Could be...almost anything.
Old Mar 18, 2010 | 06:20 AM
starcraft1's Avatar
Smile
Well that narrows it down
I will give a few things a try and let you know what I find. Could magnecor 8mm and bosch fusion plugs have a life expectancy of only 30,000 (thats how long ive had mine in). I know that anything is possible, but I just wanted to try and find out a good starting point and Im hoping that these wouldnt have gone bad that quickly ...... it was a pain replacing those wires so Id rather not do it again.
Thanks a lot
dillhole
Feb 20, 2020 02:30 PM
dmatranga
Feb 6, 2014 01:48 PM
zenithgarfunkel
Dec 21, 2013 10:26 AM
MLX665GP
Jul 14, 2008 09:10 AM
microbc
May 22, 2008 03:15 PM
