Throttle body leak
Old Mar 17, 2010 | 12:05 PM
landRoverNewbie's Avatar
Default Throttle body leak
Hello,
I was told I have a throttle body leak. I have a disco 2001 SD7. It is leaking on underneath side where the two lines connect. It looks to leak from the top of the left side. I am not sure whether I should be buying the the throttle body itself or just a throttle body heater plate kit. I also filled my coolant because it was low.
I did take a picture of where it supposed to be leaking from. But I am having difficulties with attaching to message.
Old Mar 17, 2010 | 12:32 PM
okdiscoguy's Avatar
Heater plate kit. Common problem. You can bypass it by putting the 2 hoses together with a small piece of tubing until you can get to it. Kit is under $30 to fix. roverparts.com or even check your dealer.
Old Mar 17, 2010 | 03:04 PM
Wolkesan's Avatar
Old Mar 17, 2010 | 11:01 PM
Default thank you
Thank you. The 1st link you pasted was exactly what I needed.
Old Mar 17, 2010 | 11:06 PM
Frank4's Avatar
Bypass it!!! You will never have to touch it again!!!
Let the slamming commence!!!!
Old Mar 17, 2010 | 11:32 PM
Shadill's Avatar
Bypass
Old Mar 18, 2010 | 09:42 AM
Shane83's Avatar
I bypassed mine last week and it solved the problem right away! I live in south texas so there will be no need for it, it may freeze one or two days a YEAR!!! lol.
best of luck and it only took about 5 minutes to do!
SenatorPerry
Jul 15, 2013 10:28 AM
RamblingMan
Mar 2, 2009 10:39 PM
david1289
Oct 28, 2008 12:24 PM
Luv2Disco
Oct 20, 2008 04:08 PM
Rich 00 DISCO
Jul 3, 2008 09:09 AM
