rough road signal p1590
Old Apr 21, 2014 | 09:20 PM
ls1morethanyou's Avatar
Default rough road signal p1590
Anyone ever encounter the three amigos with a p1590?
my searching has led me no where to finding a solution for this.
Old Apr 21, 2014 | 09:23 PM
ralphobell's Avatar
It is a generic code for the ABS usually produced by the Ultragauge. You need an ABS scanner to get the correct fault codes.
Old Apr 21, 2014 | 09:45 PM
i was hoping that was not the case, ill have to go borrow a scanner then. i have done the shuttle valve direct wiring fix, thinking that had something to do with it.
Old Apr 21, 2014 | 11:14 PM
tuercas viejas's Avatar
For info that code goes with the ABS fault.
Correct the ABS /SLABS fault and you will auto correct the the engine code.
T/V
dillhole
Feb 20, 2020 02:30 PM
abran
May 13, 2014 06:33 PM
jimvw57
Mar 8, 2014 04:35 PM
Urban Panzer
Sights N Sounds
Nov 15, 2008 09:50 PM
suntattoo80
Jan 18, 2007 07:22 PM
