RPM at 70 mph
Old Mar 21, 2016 | 10:56 AM
zuke's Avatar
Default RPM at 70 mph
Had my LR for a week now. The RPM at 70 mph is at 2500 rpm. It seems high and thought maybe it was not shifting into high gear. Anybody know this?
Old Mar 21, 2016 | 11:01 AM
drowssap's Avatar
i would guess mine is around 2200-2300
Old Mar 21, 2016 | 11:16 AM
Big Jim Swade's Avatar
I thought that was about where mine is. I'm running 255/60-18" tires and my speedometer is spot on with my GPS unit.
Old Mar 22, 2016 | 03:11 PM
OffroadFrance's Avatar
I can't comment on the V8 rpm but if the M&S lights are illuminated the truck is stuck in 3rd gear in 'limp home mode'. The TD5 would be around 2300 to 2500 rpm at around 70mph or 2000rpm at 60mph in imperial miles.
Old Mar 22, 2016 | 03:40 PM
number9's Avatar
That's normal RPMs. Checked mine yesterday and today to verify prior to reply.
Old Apr 12, 2016 | 07:51 PM
Dave03S's Avatar
Interesting observation,
Speedometer 70 = 2500 RPM on instrument panel.
Speedometer 70 = 65mph on Ultragauge
UG 70 mph = 2750 rpm as read on both UG AND instrument panel which now reads 75 mph.
Instrument panel differs from UG by 5 mph ish at 70mph and up.
RPM's read exactly the same on UG and instrument panel at all speeds.
Old Apr 12, 2016 | 09:57 PM
acamato's Avatar
The UG has a correction factor. There is a procedure to set in in the manual. It involves finding a road with mile markers and going a few miles and comparing that distance to the distance on the UG.
Old Apr 12, 2016 | 10:58 PM
number9's Avatar
My UltragaugeII has a similar feature for calibration and read lower than actual MPH.
Check my newly added vehicles or with new tires using interstate mile markers for odometer and then speedometer for one minute miles at 60 MPH. Will normally check over 5-10 miles and repeat several times to account for slight variation of marker placement or cruise control. Prefer to know actual miles driven to compute MPG and nice to know actual speed. My D2 is spot on for both miles and speed running stock wheels/tires.
Old Jun 12, 2020 | 08:52 AM
Sean Vassallo's Avatar
Default Landrover Discovery 2
Hi, i have Disco 2 V8 and was looking to make 35 inch tyres any suggestion what to do? Change the transfer case to 1.4 or 1.6 or change the ratio in the differential?
Driving with 70mph what do you consider the average RPM has to be?
Thanks in Advance
Sean
Old Jun 12, 2020 | 09:01 AM
frostythor's Avatar
Speedo gauges are not the most accurate instrument, any were from 5-10%, and don't for get as your tyre tread wears down the distance covered per rotation gets smaller, my sat nav is away spot on when I go through speed checks in Europe, my speedo shows any were from 3 -5 miles faster, which means if I drive to my speedo I don't get a speeding ticket
KMSDISCO
Jan 22, 2017 03:41 PM
dirtbag
Jun 3, 2015 07:51 AM
spencerfre
Aug 15, 2008 11:55 PM
Mark G
Sep 28, 2007 06:54 AM
sledmaker
May 9, 2007 05:02 PM
