What RPM is your Disco at 70 mph and tranny Q?
Old Sep 25, 2007 | 12:33 AM
Mark G's Avatar
Default What RPM is your Disco at 70 mph and tranny Q?
I'm new to Land Rovers. My 1998 Discovery runs 2,600 rpm at 70 mph, which seems high to me. Driving along, the torque converter doesn't seem to be locking up. Do these Discovery's have lock-up converters? I assume so, but normally the test (with Domestics) is to tap the brake at road speed and the speed will bump up a little. Doesn't seem to do it w/the L/R. Any advice?
Thank you
Mark G
Old Sep 25, 2007 | 02:21 AM
Randy Lover's Avatar
Default RE: What RPM is your Disco at 70 mph and tranny Q?
ive noticed that my 2003 disco II td5 raches high revs on the motorway at about 70, around the 2,700 mark.
Old Sep 25, 2007 | 06:50 AM
Landzu's Avatar
2600 rpm is about right, tire size will make a little difference one way or the other.
No the transmissions do not have lock up torque converters.
This on Disco I's like yours.
It may need a fluid change (trans)or the kick down cable set better.
Old Sep 25, 2007 | 08:20 AM
Pay attention to your tach, you will see it shift to 4th. then lock up usually at around 50 MPH on the road. By your RPM's it is safe to say you have stock size tires, if with time you up size on your tires you will see the RPM's drop a little, but for now, you are where it belongs.
Old Sep 25, 2007 | 09:31 AM
Mark G's Avatar
Thanks guys. I wasn't sure if there was a problem, but I feel a lot better now.
Mark G
Old Sep 25, 2007 | 05:11 PM
okdiscoguy's Avatar
ORIGINAL: Landzu
If they don't lock up, why do I get the feeling of shifting into 5th gear just above 50 MPH? I have a 97 and would swear it locks.
On the other question, I am right at 2500 @ 70MPH.
Old Sep 26, 2007 | 08:37 AM
Landzu's Avatar
ORIGINAL: okdiscoguy
ORIGINAL: Landzu
Thats odd the autos are only 4 speeds in the Disco I's BMW
made the transmissions for Rover.
A transmission that (locks) means the that you can slow with out
the transmission down shifting, now this can also be done with a
light foot on the go (gas) pedal but not to the extent that a
transmission with a locking torque converter can.
It was all done to save gas in cars but I have not seen this in years.
Old Sep 28, 2007 | 01:00 AM
Willie 00D2's Avatar
Mine dropped a few hundred rpms when I switched to 245/75/16 tires.
Willie
Old Sep 28, 2007 | 06:54 AM
Landzu's Avatar
I run about 2400 rpm with 245/75/16.
dirtbag
Jun 3, 2015 07:51 AM
Unlicky12
Oct 9, 2013 07:56 PM
ag2
Nov 3, 2011 08:27 AM
spencerfre
Aug 15, 2008 11:55 PM
