RPM drop at idle
Old Oct 2, 2016 | 09:01 PM
andrewd's Avatar
Default Misfire
Hi,
I have an 01 D2 156k miles. Lately there has been a slight mis at idle when in drive.
No pending codes.
Update. Ran 2 bottles of techron through the tank and drove it about 200 miles. seemed to improve it for a few days and then it really started running like crap. started missing pretty badly while driving and ended up throwing a few codes. p0304 (misfire cylinder 4) and p0150/p0152 o2 sensor bank2 sensor 1.
i have record of previous owner putting plugs in it about 25k-30k miles ago using NGK V-Power plugs when the head gaskets were done. I know a lot of people recommend only using the OEM Champion plugs, however up until this point it ran beautifully.
Any thoughts? it is sitting at the local LR indie shop but they won't be able to get to it for a few days.
Old Oct 18, 2016 | 10:13 PM
andrewd's Avatar
bump with an update to the story.
Old Oct 19, 2016 | 04:24 AM
NickAdams's Avatar
I would suspect plug wires and then spark plugs. The bank 2 O2 codes are from the mis-fire on cylinder 4.
Old Oct 19, 2016 | 10:29 AM
CharlieV's Avatar
Nick is my senior in knowledge (not sure about age), but I always suspect the MAF.
Old Oct 19, 2016 | 08:46 PM
number9's Avatar
Originally Posted by CharlieV
I alays suspect
TX attys always suspect one thing or another.
Old Oct 19, 2016 | 11:11 PM
Charlie_V's Avatar
Hahahahaha! True enough!
Old Oct 20, 2016 | 06:28 AM
dgi 07's Avatar
I would say swap the wires and see if the Misfire moves, but its sitting at your shop.
What the hell is going on in here, 2 Charlies?
Old Oct 20, 2016 | 03:44 PM
CharlieV's Avatar
I have become the consummate "throw parts at it" guy, because I have so many parts I don't need (or won't need, if you know what I mean and I KNOW YOU DO!). If anything acts up and doesn't have a clear cause, I swap an MAF in first because it is the easiest thing. Sort of like aspirin--it cures so many things. I found two new MAF's in their boxes a couple of days ago... forgot I had them. Luckily, they don't have an expiration date.
But you are right; swapping the wires of equal lengths from one side to the other would be a quick way to figure out if it is a wire issue.
Old Oct 20, 2016 | 07:46 PM
NickAdams's Avatar
Likely only senior in age: you joined the forum before me.
Old Oct 20, 2016 | 07:55 PM
NickAdams's Avatar
Yes, and two "Charlie V's."
The mis-fire code for a single cylinder points more to an item like a plug wire than a mass air flow sensor, in my mind. (I would expect multiple or random mis-fires were the problem a MAF.)
While swapping wires is a no-parts-cost way to test, Auto Value ignition wires (made by Standard Ignition) are readily available where I live and relatively inexpensive. About $30 for the set
Lord Wert
Jun 5, 2013 11:38 AM
unlikeanything
Oct 11, 2009 02:50 AM
ghostrider747
Jul 1, 2008 09:08 PM
96SE7Disco
Mar 5, 2008 10:12 AM
Brad S1
Nov 17, 2006 11:31 AM
