Rubber bushings on power steering lines
Old 04-15-2020, 08:19 AM
BigCountry's Avatar
Default Rubber bushings on power steering lines
I replaced leaking nasty power steering lines which run behind the radiator. They are held down by a clamp and rubber "bushings". After installing the new pipes, I cannot get the bushings and the clamp back together. I believe this is the same issue I had with the rubber grommets for the oil pan, in that they swelled due to oil saturation and will not go back. Based on you guys I was able to order those for the oil pan. Thanks so much. Can these "bushings" or power steering line protectors be ordered? If so please advise of their name or part number like you guys have done before. Thanks again.
Old 04-15-2020, 03:10 PM
XRAD's Avatar
that part is probably NLA.. probably could use another power steering type clamp and adapt to the LR
Old 04-15-2020, 03:30 PM
BigCountry's Avatar
I assume the main purpose of these rubber grommets are to prevent the lines from rubbing and therefore creating a hole. I was thinking to put some silicone underneath and let it dry. then go back and put the lines in the clip and put silicone between them and on top. also thinking of wrapping them with an insulating tape before clamping them back in.
Old 04-15-2020, 04:06 PM
Sixpack577's Avatar
Just split a piece of rubber hose with the correct or closest inside and outside diameters.
The following 2 users liked this post by Sixpack577:
Best4x4 (04-15-2020), Motorhead1 (04-16-2020)
brownie92
05-19-2013 03:03 PM
jfall
11-29-2012 10:05 PM
CANAMDiscovery
10-16-2012 04:48 PM
The Image
01-05-2008 05:43 PM
kjj0506
09-22-2007 06:34 PM
Quick Reply: Rubber bushings on power steering lines
