Rubber plugs by oil pan + Trans temp light
Old Jul 8, 2013 | 11:21 PM
oilspotLR's Avatar
Default Rubber plugs by oil pan + Trans temp light
Hello,
I was trying to change my transmission fluid the other day and I noticed two big rubber plugs at the end of the oil pan. They are on the side and look like they provide access to the transmission. I've noticed mine are cracked and really falling apart but I can't seem to find the part on any website.
The reason I was changing my fluid is because A) I've never done it. B )I'm having an overheat light come on just when I place the key in the ignition and haven't drove it for 3 days. I'm looking at the rave for the temp sensors... Anyone ever replaced the sensors? Oh and my fill plug is rounded off (the interior square is rounded out) but I found a transmission shop to change the fluid for $60. I just don't want to screw it up driving there!
Old Jul 8, 2013 | 11:53 PM
LRScott's Avatar
The rubber plugs are inspection ports for the flywheel. Does it keep throwing the light, or has it just been the one time?
Old Jul 9, 2013 | 12:16 AM
BCDisco2Lando's Avatar
Part number for the plugs are ERR7229 and you need 2 of them.
Old Jul 9, 2013 | 12:36 AM
There are two sensors, one for transmission, and one for transfer box. Either one can make that light come on. Or a skinned wire. Page 93 of 126 in the early circuits manual. To see locations, look up connector in electrical library.
Old Jul 9, 2013 | 11:04 PM
oilspotLR's Avatar
It keeps throwing the light. It throws it at random though. I mean it can't be actually over heating when I haven't drove it in a week and I just put the key in the ignition!
THANK YOU!!!
Thank you for explaining the fact that it could be the transfer case and not the transmission!
Old Oct 30, 2015 | 02:46 PM
elrocha69's Avatar
Don't take those out, or you'll NEVER get them back in. Ive been battling mine since i put a rebuilt engine in to bo avail lol
Old Oct 30, 2015 | 03:47 PM
R0VERGUY's Avatar
Yeah the old ones do not go back in very easy as most have had oil dripping on them and they have expanded to the point they are almost popping out. The new ones should be much easier to install then an old used one.
tdmadlem
May 21, 2015 06:09 AM
Jared9220
Sep 25, 2012 08:45 AM
Robmcin
May 10, 2009 05:08 PM
bamarover
May 21, 2007 08:24 AM
bamarover
May 18, 2007 09:33 PM
