Rumble
Old Mar 22, 2016 | 03:33 PM
redrover75's Avatar
Default Rumble
More like a rhythmic hum at 65+mph. Maybe about 2hz.
When i turn the car slightly to the left it goes away.
The truck tracks straight, no issue with alignment.
Any ideas where to start?
Old Mar 22, 2016 | 03:41 PM
OffroadFrance's Avatar
Sounds like front drivers side wheel bearing if it disappears turning left or could be auto or transfer box bearings but less likely. I reckon front LHS wheel bearing, usually barely audible a low speeds but slightly louder around 55 to 75 mph.
Old Mar 23, 2016 | 09:26 AM
redrover75's Avatar
Default thank you
Great response!
This makes sense, as my three amigos is coming back intermittently lately. replaced the shuttle valve a year ago.
Also, need to do the front brakes too. good timing.
Is there any value in a used front hub? Or is that a fools erand?
Thanks,
Old Mar 23, 2016 | 11:04 AM
DiscoCam's Avatar
Originally Posted by redrover75
Great response!
Thanks,
Go for a new hub. It is just one of those things that you don't really buy used because they wear out.
Old Mar 23, 2016 | 11:55 AM
dgi 07's Avatar
Ditto on wheel bearing.
I did used hub assembly from Paul Grant for a considerable savings. And its still good 30k miles later.
Offroad France, good to see you are still kicking.
Now if we can just get Dusty back, the bands all here!
Old Mar 23, 2016 | 12:16 PM
Externet's Avatar
The 2 Hz part could be related to different L&R tires circumference. By wear, brand or inflation.
I did lubricate noisy wheel bearings successfully and extended their lives. So far, two+ years, and noise vanished.
Old Mar 23, 2016 | 02:52 PM
Glad to be alive and kicking, but as they say, it's never over till it's over.
It would be great to see/hear from Dusty, he's a real gem and trooper with lots of LR knowledge and very humorous and dry with it
Old Mar 23, 2016 | 02:56 PM
IMHO as the price of new hubs is relatively cheap now IMO go for a new hub albeit Pauls are probably good and original items they can still expire as can new but the difference is the new has at least a one year warranty.
Old Mar 24, 2016 | 08:21 AM
redrover75's Avatar
Default Brit Part
There is TAY100060 by Brit Part for ~$100. seems much less than others, any reason not to buy it?
jallert
Dec 13, 2009 11:34 PM
range03
Apr 14, 2009 06:33 AM
mattlapper
Aug 8, 2007 09:40 AM
maverick544
Aug 3, 2007 05:54 PM
dbs600
Apr 16, 2007 01:20 PM
