Running Rough
Old Dec 18, 2006 | 11:15 AM
wascaps's Avatar
3rd Gear
Default Running Rough
I have a 2000 Disco with about 78,000 miles on it and it is running rough. I pulled the codes and get the following: P1300, P0303, P0302, P0300, P0303, P0302. I replaced the plugs and wires about 2 months ago. Does anyone have an idea before I take it to the dealer.
Old Dec 18, 2006 | 12:04 PM
Default RE: Running Rough
All the 300 codes are for mutiple misfires on cylinders 2 and 3, I can't find the 1300 code yet.
How did it run after you first installed the new wires and plugs, who's plugs and wires did you use?
Mike
Old Dec 18, 2006 | 12:58 PM
wascaps's Avatar
3rd Gear
It ran fine but it would run rough every once in a while when it was damp (but not everytime it was damp).
I used Bosch FR8DPX plugs and a wire set from KAR products(from Drivewire.com).
Old Dec 18, 2006 | 04:39 PM
Do you have a check engine light on?
Mike
Old Dec 19, 2006 | 11:14 AM
wascaps's Avatar
3rd Gear
Yes, the check engine light is on and occasionally flashes.
Old Dec 19, 2006 | 12:09 PM
I wish I knew what the 1300 code is, I have a feeling it is causing all your misfires.
Mike
Old Dec 19, 2006 | 12:54 PM
mr.47's Avatar
Hi
I got a list of fault codes and it seems that P1300 isBoost calibration fault.
Thx
Old Jun 8, 2007 | 03:14 PM
funkate's Avatar
I just had the exact same problem and codes come up. My wonderful mechanic figured out that it was a clogged fuel rail. He clean it out, replaced some part, and cleaned my injectors and she's running fine now.
Old Jun 8, 2007 | 03:22 PM
Well in his particular case those are all cylinder misfire caused by old plugs and wires.
Mike
dillhole
Feb 20, 2020 02:30 PM
sidneype
Sep 10, 2008 07:49 AM
PMROBERTS
Sep 29, 2005 11:50 AM
cottonpatchweims
Aug 15, 2005 11:19 PM
sidneype
Jun 30, 2005 07:21 PM
