rythmic thumping
Old Apr 29, 2008 | 06:14 AM
zerochills's Avatar
Default rythmic thumping
The past two or three times i have had my truck out I have noticed while at slow speed (<10mph) and not accelerating I am noticing a rythmic thumping. Similar to a bad hub/wheel bearing. I have jacked up each wheel and checked for play in the bearing and did not find anything to obvious.
Is it possible it could still be a hub, or more likely something else?What couldI look for?
Old Apr 29, 2008 | 07:59 AM
Default RE: rythmic thumping
How many miles on it, have you replaced the 2 bad u-joints on the front drive shaft?
Old Apr 29, 2008 | 09:02 AM
zerochills's Avatar
Just hit 140000mi, replaced to u-joint about 12000mi. ago and greased twice (every 5000mi.)
Old Apr 29, 2008 | 01:50 PM
zerochills's Avatar
hopefully I can rule out tires, I have about 25-30% tread life remaining. No signs of uneven wear. ???
Old Apr 29, 2008 | 05:33 PM
Rotate the tires front to back and see what happens with the noise, if it moves from the front to the back...its your tires.
JMYERS23
Mar 16, 2013 09:38 PM
kskinner
Freelander
Oct 1, 2011 01:50 AM
NhudeST
Sep 1, 2011 11:22 AM
paso96D1
Oct 17, 2009 08:10 PM
