SAI hoses and pending codes...
Old Jan 14, 2013 | 09:19 AM
AdrenalinPlease's Avatar
Default SAI hoses and pending codes...
So while replacing the tstat, bleeding coolant, fumbling around under the hood I broketeded the vacuum hose for the SAI, a really tiny skinny hose. Now Im getting pending codes all the time P1415 and P1417 which are for SAI, where I get said hose? Or rather the size? Can I use a universal hose on there?
Old Jan 14, 2013 | 09:27 AM
System will be happy if you replace with good fitting universal hose that can take the temperature. That hose is trying to operate a valve and the system is testing periodically to see that it does work, and telling you that it does not. Because it is vac hose, you don't want the most wimpy stuff that will collapse under a vacuum.
Old Jan 14, 2013 | 09:36 AM
Is there a good quality hose that I should look for? I mean I have vac hose in my shop but I dont know if its good enough for this application?
Old Jan 14, 2013 | 09:43 AM
Slice off a piece of original and head to parts store. If you have something on hand use it, but maybe look to see if something better is available.
Old Jan 14, 2013 | 10:35 AM
Will do! Thanks!
Old Jan 14, 2013 | 12:00 PM
drowssap's Avatar
try checking fuel injection hose if you can find it in the correct size, it is much stronger that standard rubber hose.
Old Jan 14, 2013 | 12:06 PM
KNow the size off the top of your head? Its really tiny.
gatorm
Aug 11, 2017 04:04 AM
Antmen
Jan 16, 2013 03:53 PM
keoni004
Nov 4, 2012 05:06 PM
jkid
Nov 29, 2008 04:48 PM
bcolins
Oct 7, 2008 07:19 PM
