SAI and non SAI in donor
Old Aug 9, 2017 | 03:13 PM
2 discos's Avatar
Originally Posted by RoverMasterTech
Use the non Sai engine and just swap the bcm and ecu. Ur welcome
well I switched over the ECU and the BCM from the 2001 to match the engine and now it doesn't want to turn over it just clicks so then I switch back the BCM from the 2003 and it's doing the same thing
Old Aug 9, 2017 | 04:25 PM
Alex_M's Avatar
You need to replace your MAF sensor and be sure to use a Bosch unit. Try that first, might fix all your issues. If you're still having problems replace the crankshaft position sensor. That one you can go to any auto parts chain. I know the house brand sensor at AutoZone is actually a Bosch sensor in a different box.
Old Aug 11, 2017 | 04:04 AM
abran's Avatar
you have an immobilizer fault. You need to clear that with a decent code reader or try a hard reset.
rreinholt
Sep 19, 2013 05:25 PM
roverbob
Sep 2, 2012 08:34 PM
Lincoln Tarantino
Jun 8, 2012 11:18 AM
Lincoln Tarantino
Apr 5, 2012 08:51 AM
uh60driver
Apr 2, 2012 11:22 PM
