SAI routing and connection diagram?
Old Jan 9, 2016 | 03:08 PM
The_OGCJR's Avatar
Default SAI routing and connection diagram?
I recently bypassed my TB and replaced some SAI vacuum lines with rubber hose. But, I think I have them routed wrong because now I get p1414 and p1417.
All the diagrams i've seen online don't show all the detail of where each hose connects, just the hose it self. I couldn't find it in RAVE either.
Anyone?
Old Jan 11, 2016 | 07:17 PM
chubbs878's Avatar
I could explain it to you but that's the best i can do. Also, if the hose isn't secured well on the fitting before you tighten down the clamp, it won't seal properly. I went back and forth with it for a few days when I had it all disconnected. It just wasn't getting a good seal on one of the connections.
Old Jan 11, 2016 | 07:36 PM
chubbs878's Avatar
use this diagram...
Old Jan 11, 2016 | 07:38 PM
chubbs878's Avatar
This small line on vac-reservoir to sol valve, like it says
Old Jan 11, 2016 | 07:41 PM
chubbs878's Avatar
This guy, #2, sol valve
Old Jan 11, 2016 | 07:42 PM
chubbs878's Avatar
There are 2 lines connecting to it, they are angled so each attaches just the right way
Old Jan 11, 2016 | 07:46 PM
chubbs878's Avatar
Crossovers tube on firewall to Pass side control valve and SAI pump. Loosen clamps and refit hoses. Then re-tighten very snug
Old Jan 11, 2016 | 07:49 PM
chubbs878's Avatar
Crossover tube on firewall to driver side SAI control valve, near SAI solenoid and its 2 lines where we started. One again, loosen clamp, reseat hose and tighten up clamp really well again.
Old Jan 22, 2016 | 08:24 AM
The_OGCJR's Avatar
Thank you chubbs.
gatorm
Aug 11, 2017 04:04 AM
grandkodiak
Jul 3, 2013 02:56 PM
roverbob
Sep 2, 2012 08:34 PM
uh60driver
Apr 2, 2012 11:22 PM
NiteTrain
May 6, 2010 10:27 PM
