SAI tubing alternative/mod
JUKE179r, has your pump continued to run more frequently than you remember or has that behavior abated? I know the system goes into self-test mode occasionally but recently I've been noticing my pump come on at red lights to. As soon as I press the accelerator the pump shuts off. Last night I barely came to a full stop and the light changed, I don't think the pump even got up to full speed by the time I pressed the pedal and it shut right off again. I don't remember this happening as often. I noticed it about a month ago and then it disappeared, after not having it really happen at all in the last year. And then I've heard it over the last two nights.
I don’t know why the pump turning on at stops problem suddenly stopped for me. My SAI pump works great since I posted about it back in August. I didn’t change anything in the SAI system or the electrics (I only installed an alternator).
These trucks are weird...
I removed my hard SAI tubes and followed JUKE179r's directions for the SAI soft tube mod and everything went smoothly!
The only difference is that I ordered the following:
McMASTER-CARR 5133K25 High-Temperature Vacuum-Rated Coolant Hose, 3/4" ID, 1-1/16" OD, 5 Feet Long
Dorman Help! 47118 Heater Hose Tee
sanderjoems7
Nov 5, 2019 04:44 PM
