SAI valve
Old Jun 10, 2015 | 08:32 AM
redrover75's Avatar
Default SAI valve
How would I test my SAI valves? Or more to the point, how would I confirm that a used one works?
Also, does anyone know of a kit of vacuum lines that i should replace while im in there?
Old Jun 11, 2015 | 01:25 PM
Joemamma1954's Avatar
the valve is a spring loaded valve, when vacuum is applied the valve opens up. I just put on on a small tube to the valve and applied suction, while holding the valve to see if there was any movement and i could feel something kind of click or move. then i put my tongue on the tube i was applying suction to, to see if it would hold a vacuum and it did. when i released, i felt it move back. I believe the two things that can go wrong, 1 the valve sticks open or closed, 2 the vacuum diaphragm inside has a hole in it. valve sticking can usually be cleaned out with carb cleaner, compressed air, then applying vacuum on and off until it is freed up. hole in diaphragm cannot be fixed.
hope this helps som
gatorm
Aug 11, 2017 04:04 AM
roverbob
Sep 2, 2012 08:34 PM
uh60driver
Apr 2, 2012 11:22 PM
landover
Mar 15, 2011 07:53 PM
Rich 00 DISCO
Apr 24, 2009 11:18 AM
