Scary indicator issue.
Old Jul 5, 2018 | 03:26 AM
JUKE179r's Avatar
I see a lot of spliced wires in your pics. Proceed with caution!
Old Jul 7, 2018 | 02:03 PM
Derek Gjessing's Avatar
I Finally figured out what was causing the problem. Found out that the windshield had been changed some time in the past. Its been pretty dry here in norway since i bought the car, but when it finally started to rain i saw the water was coming in to the car. Figured the header joints would be a good starting point, so i picked apart the dashboard. OH MY GOD! at one point there must have been ALOT of water inside this car. previous owner has been in there and tried to solder some of the connections and has done a horrible job at it. Luckily only two of the header joints were bad plus the bodgy soldering. Soldered the bad connections together using the RAVE manual and bingo! Turn signals work perfect + the horn and cruise control work now. For the record; I`ve fixed the leaky windshield, so hopefully no more water will come in to the car. Thanks for the help guys.
djdart
Nov 14, 2015 01:03 PM
jimmyc
Dec 9, 2013 01:22 PM
bballjames
Nov 27, 2012 11:46 PM
ducrider
Sep 9, 2007 05:52 PM
LordOphidian
May 30, 2006 03:00 PM
