sea foam
Old Apr 25, 2009 | 04:56 PM
newtolandie's Avatar
Default sea foam
What size of hose do I need to do the sea foam? cheers
Old Apr 25, 2009 | 06:47 PM
Use the PCV hose, no extra hose is needed.
Old Apr 25, 2009 | 07:49 PM
AK Rover's Avatar
The PCV is the hose going from the passenger side valve cover to the intake plenum. Use pliers to restrict the flow so it takes 1-2 minutes for the engine to suck in the whole can. Once it's in the engine turn it off and let it sit for 30 minutes then drive it like you stole it and watch it smoke in the rear view. While you're waiting for the Seafoam to work use an entire can of throttle body cleaner and clean the throttle body. Make sure to open the butterfly valve and spray inside really good.
bigugly82
Mar 14, 2018 05:09 PM
DeepBlueWater
Oct 16, 2007 10:23 AM
Camdisco24
Aug 7, 2007 04:44 PM
mowthat
Feb 14, 2007 10:03 PM
mikemeyer0
Jun 16, 2005 04:00 PM
