Sea Foam
Old Oct 15, 2007 | 06:39 PM
DeepBlueWater's Avatar
Default Sea Foam
I'm considering doing the SeaFoam induction cleaning on my 2003 Disco.
I found this detailed information on using Seafoam and hope to get some input on the accuracy andapplicability to the Disco.
http://www.ls1tech.com/forums/showth...hlight=seafoam
MWmG
Old Oct 15, 2007 | 06:49 PM
okdiscoguy's Avatar
Default RE: Sea Foam
I wouldn't put it in the crankcase. Do an ATF flush. I have used 2/3rds of a can on the induction cleaning, just as described. I haven't used the deep creep on the T-body. I actually use THrottle body cleaner to get that one. Use the seafoam, clean the T-body and then do a flush with ATF.(drain oil, fill with ATF DO NOT DRIVE!! Idle for 20 min, drain and fill with your favorite oil. I would change the oil at 1K after that just to get out any ATF that may have stayed..
Viola! New Disco
Old Oct 15, 2007 | 06:53 PM
Thanks,
I did the ATF flush last week per your advise. Worked well.Working on the 1000 miles to change the oil again.
MWmG
Old Oct 15, 2007 | 06:59 PM
okdiscoguy's Avatar
Do the induaction cleaning before you change your oil. Seafoam might creep past your rings and blow out the carbon built up.
Old Oct 15, 2007 | 08:50 PM
ajh's Avatar
ajh
Why flush with ATF vs just another cheaper mineral oil?
Old Oct 16, 2007 | 10:23 AM
98roverguy's Avatar
ORIGINAL: ajh
ATF consists of mostly detergent. It cleans far better.
bigugly82
Mar 14, 2018 05:09 PM
Kraftyz51
Oct 21, 2007 10:25 AM
Camdisco24
Aug 7, 2007 04:44 PM
mowthat
Feb 14, 2007 10:03 PM
mikemeyer0
Jun 16, 2005 04:00 PM
