Seat relay location?
Old Dec 29, 2015 | 09:04 PM
mx468's Avatar
Default Heated seats not working
Ok just installed seat heater switches to my new used Disco 2, I have the relay boxes under the seats. The disco never had heat switches installed so this is the first time. The heating elements have never been used. I'm getting no heat where do I check next?
Old Dec 30, 2015 | 06:05 AM
drowssap's Avatar
you don't have much info on the new DII, but it does have to have a leather interior.
on my 2000 i simply plunged the switches in and the heated up.
Old Dec 30, 2015 | 11:03 AM
mx468's Avatar
It's a 2000 disco 2 with leather seats. I installed the switches and the switch lights work when I push the buttons but seats only get about Luke warm. Barely any heat but definitely a little.
Old Dec 30, 2015 | 06:11 PM
Alex_M's Avatar
If they're working but only kinda then the problem is most likely with the heating pad. Never experienced it myself, but I've heard that once they start acting buggy like not heating up completely then you should stop using them until you replace the pads because they can actually cause an electrical fire. Just regurgitating the word of warning I read when I was researching doing the same.
Old Dec 30, 2015 | 11:47 PM
mx468's Avatar
Even if they have never been used before?
bleizit
Jun 24, 2020 04:03 AM
RicketyTick
Jun 24, 2014 06:58 PM
s10lowrider1994
Oct 6, 2011 01:22 AM
Hayne
Feb 25, 2010 01:56 PM
Roveroh
Aug 7, 2008 09:42 AM
