Secondary Air issues
Old Apr 4, 2014 | 09:36 AM
Yoops Racing's Avatar
Default Secondary Air issues
Can anyone tell me what they have done when you have these?
P0412 Secondary Air Injection System Switching Valve ACircuit Malfunction
P0414 - Secondary AirInjection System Switching Valve A Circuit Shorted
Old Apr 4, 2014 | 02:39 PM
What no issues? Impossible :-)
Old Apr 4, 2014 | 03:26 PM
ralphobell's Avatar
Patience Grasshopper. Not everyone sits on the thread all day. I don't have secondary air, so I'm no help.
Old Apr 4, 2014 | 07:57 PM
Jared9220's Avatar
okay, I did some research in the rave and this is what I found:
SAI fault code info.pdf
Both of your codes are related to the SAI vacuum solenoid valve. I would check to make sure that the plug is plugged all the way into the valve and the little metal clip is holding it firmly in place. Also make sure that the pins in the solenoid are not bent and blow out the plug with an air compressor to make sure there is no water in there and then pack some dielectric grease in the plug and hook it back up. The vacuum solenoid is located right next to the purge valve.
Follow the wire harness and make sure there isn't and short in it. If everything else looks good then I would recommend getting a new vacuum solenoid- Solenoid - Secondary Air Injection (Genuine Part # YDJ100000) - Land Rover miscellaneous from Atlantic British
Old Apr 5, 2014 | 11:50 AM
Thanks that is exactly what I need
David
ajh
Sep 12, 2011 09:28 PM
jdelp
Oct 23, 2007 11:53 AM
jdelp
May 30, 2007 03:49 PM
akartis
Sep 25, 2006 01:31 PM
forbin10
Dec 21, 2005 06:51 PM
