serious problem help!
![Exclamation](https://landroverforums.com/forum/images/icons/icon4.gif)
Sounds like your door lock is hosed... Without it, you're going to have difficulty turning off the immobilizer.
Check out https://landroverforums.com/forum/di...d-works-45005/
As your door lock is preventing that, I seem to recall another post that will help you:
https://landroverforums.com/forum/di...ck-mode-48879/
Best of luck!
Best of luck!
Best of luck!
Best of luck!
I am not sure if I have a problem or not. perhaps a bad sensor? I notice the fan is usually on though.
the lights on a land rover are not so much "idiot" lights.. more self destruct sequence initiation warnings. my self, I'd rather drain a diff on the side of a road than drive one mile with a light on the dash.. I'd be seeing whats going on. a trans filter is a pretty straight forward job. if you havent done one I'd do it before driving anymore. and the diff is even easier..
I just changed the diff fluid, tranny fluid and transfer case fluid maybe 2000 miles ago with premium, synthetic AMSOIL Severe Gear 75W-110. I can't imagine I would need to change it again would I? I also changed the transmission filter at this time.
What is a good way to check and it is possible that I can find out easily which component it is? is there a tranny dipstick?
No dipstick.
Easy way to find out which component, since they are normally open switches, which close to indicate a problem, is to unplug one at a time. As for checking fill level, under the truck some one will wiggle. See attached. It has always been written in Murphy's Law that any O-ring removed for inspection shall be torn by the process.
Here are some pages from the RAVE that cover these issues with pictures. It is important to note that while fluid may have been changed recently, it is a Rover and there is always the possibility some has leaked out.
