Serpentine Belt
Old Jan 3, 2011 | 04:13 PM
Jabez's Avatar
Default Serpentine Belt
I was curious if the fan must be removed to change the serpentine belt or can you slip the belt on and off over it?
Thanks,
Old Jan 3, 2011 | 04:41 PM
No, just remove the tension on the belt tensioner and slip the old belt of. Make sure you put the new one back on the same direction of the pulleys.
Old Jan 3, 2011 | 08:09 PM
MB00D2's Avatar
5th Gear
What Mike said. But also look at the Rave manual to see the procedure. It takes a 15 mm soket/wrench.
I do not have the ACE system, so my belt bypassed it, but it follows the diagram provided by the belt manufacturer. I started to loop it back from the top clockwise, it was a bit of a pain. But all is good now. Advanced auto part number 5070923 for NON ACE 2000 Discovery.
Old Jan 4, 2011 | 09:53 AM
Jabez's Avatar
Default Thanks
Great, thanks for the help.
joshsrover
Apr 2, 2008 11:03 AM
aublec22
Sep 15, 2007 09:05 AM
Benhamtroll
Aug 17, 2006 11:45 AM
Thegix2
Nov 22, 2005 09:25 PM
esaycho
Oct 12, 2005 03:24 PM
