Service Engine Light
Old Nov 5, 2008 | 01:05 PM
bklahl's Avatar
Default Service Engine Light
Hey all, I found a thread where it said I could turn this light off by finding a relay in the passenger area and putting a paperclip in while the engine is running to reset this light is this going to work for my year Disco 1996. any help would be appreciated
Old Nov 5, 2008 | 01:29 PM
bklahl's Avatar
Default RE: Service Engine Light
I found the answer to my own problem. There is a small box that says emmission maintenance reminder on it and if you inplug it the light goes off. it comes back on when i plug it in but I live in arizona and if that light is on they will not do an emmissions test. So I am just going to unplug it for the test and plug it back when done just in case it needs to be plugged in for some reason.
Old Nov 5, 2008 | 02:10 PM
hazletbassist89's Avatar
It will work. With the car on just stick a paper clip in the LR emblem. You'll feel a small hole and it will go through and short it out, resetting the reminder. You should get your codes read though, there could be another problem.
Old Nov 5, 2008 | 03:05 PM
The "service engine soon" and "check engine" are two seperate lights and mean two different things, the one that you are thinking of hazlett is the "check engine" light, that is the one that lets you know that there is a stored fault, the "service engine soon" light stores no faults, it is strictly a emissions reminder, meaning to check your O2's, secondary air, cats, etc for proper operation and to repair/replace as nesassary.
Old Nov 5, 2008 | 03:10 PM
oh crap, thank you for clearing that up Spike. 3.5 hour classes can really turn your brain into jelly.
Old Nov 5, 2008 | 03:12 PM
Sure, blame it on the classes. lol
Old Nov 5, 2008 | 03:13 PM
No comment.
kcferna
Jul 7, 2009 08:33 AM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
blackrover
Aug 20, 2007 06:40 PM
97LANDISCOVERY
Aug 19, 2007 04:10 PM
97rover
Apr 13, 2005 02:19 AM
