service engine light on......
Old May 26, 2010 | 01:30 PM
Danny Lee 97 Disco's Avatar
What is involved in replacing the O2 sensors? Don't they just thread in?
Old May 26, 2010 | 01:34 PM
lipadj46's Avatar
Yes, they are pretty easy in theory to change with the right tools. Getting the old connectors apart after many years is actually the harder part.
Old Jun 2, 2010 | 09:51 AM
Ilovemyroverbut....'s Avatar
I had all 4 brand new o2 sensors removed, and they were already black with like smoke residue.I exchanged them and got new sets but i don't want to replaced them to have to same thing happen. the mechanic said something bout some rod or pipe not burning the oil properly.... something to dat sort, anyone has an insight?
Old Jun 2, 2010 | 12:45 PM
90% of O2 faults on Rovers is due to the need of a tune up, that means new plugs and wires.
Weak spark will send to much unburnt fuel down stream and foul the O2's and once fouled they will not work correctly and the ECU will read that as non responsive (bad O2)
Just because you do not have mis fire codes does not mean your plugs and wires are still good.
If they put new plugs and wires on when they did the head gaskets then it is a bad MAF I would say.
Old Jun 3, 2010 | 04:36 PM
hey spike555, i had new plugs and wires all the works put in when i replaced the engine head, omg that disco runs so smooth compare to when i got it. the mechanics says it not the MAF, i still haven't put the plugs on as yet. when i get these things taken care off, i hope the service engine light goes off
Old Sep 8, 2011 | 10:00 PM
carlos's Avatar
Default looking for an update.....
hey rover lover, i was looking for an update on your disco. i think i have the same problem.
thanks
carlos
Old Sep 8, 2011 | 10:16 PM
carlos's Avatar
Cool need help, losing the battle
hello everyone, first timer. im having a problem with my 2000 discovery,.ever seens my engine light came on, different codes keep poping out.
p1663
p0500
p0115
p0135
p0154
p0134
p1590
help,
thank you
kcferna
Jul 7, 2009 08:33 AM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
blackrover
Aug 20, 2007 06:40 PM
97LANDISCOVERY
Aug 19, 2007 04:10 PM
97rover
Apr 13, 2005 02:19 AM
