service engine soon
RE: service engine soon
ORIGINAL: Disco Mike
So after all the confusion, do you under stand what you need to do regarding your check engine light, it is on cause you have a problem and will need to be scanned for codes, repaired and then reset with the proper scanner, many scanners won't do a clearing on a Rover.
Mike
Mike
you say many won't,so is there a scanner I can purchase that will clear codes off the land rover discovery? Mine is a 2003. I want to purchase a scanner to diagnosis my rover, but I would like to be able to clear codes, too. If you have any suggestions on one to get and links to where to get it from, that would be nice.
chris
rinmud
10-01-2005 04:32 PM
