service engine soon light
Old Jun 14, 2014 | 04:44 PM
Reza's Avatar
Default service engine soon light
Hello, I've had a service engine light on for a couple of weeks. My 2004 Discovery II has 73,000 miles on it. Nothing appears wrong with it. Is there anything that I need to look into here or is it just a service reminder. Since I've been changing oil, etc. myself, is there a way to turn it off?
Thanks
Reza
Old Jun 14, 2014 | 08:12 PM
ralphobell's Avatar
You need to have it scanned and see what the error codes are. Could be many things.
Go to an Autozone, etc. and ask them to scan and give you the codes. Then report back.
Old Jun 15, 2014 | 04:26 PM
Reza's Avatar
ok. the scan says ECM has detected a large leak in the EVAP system.
probable causes:
loose or defective fuel cap.....(checked fine).
Evap cannister broke, hose cracked or not connected.
Purge or vent solenoid defective
vacuum leak at engine
Where do you guys think I should start?
Reza
Old Jun 15, 2014 | 04:58 PM
Dane!'s Avatar
Gas cap?
Old Jun 15, 2014 | 07:23 PM
Reza's Avatar
caps on tight
Old Jun 15, 2014 | 08:07 PM
acg's Avatar
acg
A defective purge valve is one of the more common causes. I had replaced one a few months ago for around $70.
Old Jun 15, 2014 | 11:00 PM
jfall's Avatar
Had that code.
I took off the gas cap and put it on again.
Cleared the code with the OBD-II scanner.
Code never came back.
Was a 2001 with about 106,000 miles on it.
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
jerrytrancik
Jan 9, 2008 05:52 PM
jerrytrancik
Dec 9, 2005 03:04 PM
Woody Reems
Nov 29, 2005 06:08 PM
rinmud
Oct 1, 2005 04:32 PM
