Service Engine Soon light flashing
Old Feb 3, 2021 | 12:32 PM
  #21
Steven Hill's Avatar
5th Gear
Default Cel flashing
Ok I just pulled out the new plug it looked to be fouled out it has a little carbon build and looks to be a little wet. Can’t really tell what it is I was thinking gas due to a faint smell. But could it be water. I just replaced the head gaskets in April of last year. Not getting any other code besides the misfire on cylinder 6
Old Feb 3, 2021 | 12:56 PM
  #22
Dave03S's Avatar
Coolant doesn't have to be coming from a failed head gasket, it could be a cracked block behind the liner in 6. The next test is to get the engine up to operating temps, then pull plug 6 and inspect the combustion chamber with a cheap USB boroscope camera. You will then see where the likely coolant is entering from.
Old Feb 3, 2021 | 04:55 PM
  #23
Extinct's Avatar
Flashing CEL means dead cylinder. Start by swapping plugs left to right, then wires, then coils till it moves. If it never moves you have a bad cylinder. #6 rarely blows a hg or cracks a block, but it is possible. Good luck.
RawFaith
Jan 6, 2017 11:05 AM
marjac
Feb 10, 2012 08:01 AM
snugg
Feb 1, 2010 02:52 PM
casanova00
Jul 28, 2008 10:57 PM
cgrija1558
Oct 6, 2007 09:40 PM
