Service Engine Soon Light on and motor misfiring
Old Jun 10, 2009 | 12:50 PM
okdiscoguy's Avatar
premuim only or it will run like you are describing. Check the codes and get back.
Old Jun 11, 2009 | 01:06 PM
richey50's Avatar
Ok I got the codes and they are as followed;
1) P0130 O2 Sensor Bank #1
2) P0171 Lean Bank #1
3) P1171
So let me know what you guys think and what I shoud do.
Thanks
Old Jun 11, 2009 | 04:35 PM
Originally Posted by tailchaser0527
Spike, how could you possibly have come to the conclusion that plug wires are the problem?? I agree that replacement plug wires are a good idea for maint. But they are not the reason for as many problems as suggested on this site..
I suggest that because 90% of all rough running engines is because of worn out plugs and wires.
And being that his sisters truck is a '04, which means that it is 5 years old, and using the US average of 12,000 miles per year per car that would put approx 60,000 miles on the truck, which is right at the begginning of the time when plugs and wires wear out and need replacing.
Now had he posted the miles on the truck in his original post I would have suggested something else.
Old Jun 11, 2009 | 04:38 PM
3) P1171
Thanks
Clear the codes, start using premium gas and see what happens.
Make sure that you tell her that if she does not use prmium gas the truck will nickle and dime her to death and it will never run right.
Old Jun 11, 2009 | 08:44 PM
tailchaser0527's Avatar
Ditto,
Clear the codes, put some good premium in and maybe a little carbon free or seafoam in the tank.. More than likely the problem is coming from using 87 gas, rovers don't like it, it doesn't burn well, and causes carbon to build up on everything past the fuel injectors. Cylinders,rings, valves, and all exhaust including o2s, and catalatyc converters..
Didn't mean to step on any toes. It seemed like a quick diagnosis, and I didn't want him to run out and spend the money for wires if they wouldn't solve his problem..
I can't speak for everybody, but I don't have the budget to replace parts that don't necessarily need it.
Old Jun 11, 2009 | 11:59 PM
richey50's Avatar
Thank you guys for all your input and I will pump some 91 oct gas.
Thank you all and I will keep you guys updated.
BlackDiscoII
Jun 2, 2012 08:58 PM
richey50
Feb 6, 2011 10:04 AM
Bob2003Discovery
Jan 22, 2009 09:12 PM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
msturdy
Jul 13, 2007 11:04 AM
