Service Engine Soon light - need help - have codes
Old Oct 14, 2009 | 07:50 PM
bearcatfans's Avatar
Default Service Engine Soon light - need help - have codes
I keep getting emission codes and I dont want to throw money at parts (o2 sensors, purge valve , gas cap) that may not fix the problem. Any help would be greatly appreciated. The codes are: P1481 , P1171 , P1174pd , and P0441pd.
thanks,
-Aaron
2003 Discovery SE7 99,000 miles
Bought in '06 for $13,500, put nearly $13,000 into it since!!
Old Oct 15, 2009 | 06:50 AM
Can anybody please help me?
thanks in advance,
-aaron
Old Oct 15, 2009 | 08:42 AM
lipadj46's Avatar
I cannot find anything in the Rave manual about P1481 or P0441 but P1171 and P1174 lean on banks 1 and 2. You are not getting any O2 specific codes that I can see. The other codes from a google search seam to suggest a purge valve or maybe a bad fuel pump. Not really areas I know too well but I will give you a free bump. I would start to read the rave cd on fuel deivery to trouble shoot your fuel system someone will come along soon with better advice..
Old Oct 15, 2009 | 09:12 AM
481, is a fault code for your cooling fan control malfunction, this is the most important cause most likely your electric fan is not coming on either with the a/c on or at operating temp while doing stop and go driving.
441 is an incorrect purge flow for the evap system, valve may be going bad.
Can't find the 1481 and for now, I wouldn't worry about the 2 lean codes till additional codes show up to give you more specific information.
flybyjlane
Aug 17, 2012 08:40 AM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
And4848
Aug 14, 2008 08:53 AM
samue23
Jun 11, 2007 07:11 PM
