Service engine soon - M & S Lights
Old Nov 6, 2010 | 01:32 PM
You want the limp mode to go away, you have to fix the fault, then the M&S and other codes can be turned off.
Don't keep driving it while in Limp mode or you can cause additional damage.
Old Nov 6, 2010 | 03:39 PM
Night Train's Avatar
Thats exactly my point minus the fact that through this forum I am trying to find out WHAT THE FAULT IS to fix?????
Not yelling only trying to emphasis I have no idea what is causing my problem
Thanks
Robert
Old Dec 12, 2010 | 04:20 PM
Default Update
Posting this as a closer for this thread, I replaced my XYZ switch today and all is good. I went out, had the codes erased and nothing came back. I went with a new one from AB, I prefer new electronic parts. Anyways it was pretty straight forward operation with the advice of Disco Mike and the local garage, that actually let me borrow the alignment tool over the weekend (since its closed then). I'm not sure how much the tool is needed (since I used one) but with the slide slots for the bolts I can see were there would be plenty of room for mixing up the gears - kinda like having someone else pull all your plug wires then you put em back where ever you want.
Thanks for all the help.
Old Aug 31, 2013 | 04:39 PM
erietim's Avatar
night train I have the m/s flashing when I put it in reverse also showing code p0705 is the xyz switch the fault, battery and alternator good cleaned all grounds ps where is the dang thing on a 04 disco 2 I don't know how to move around in here please message me or email erietim@yahoo.com
Old Aug 31, 2013 | 04:59 PM
In the future, start your own thread instead of using a near 3 year old one.
buick215
Aug 2, 2011 08:36 AM
hriant88
Mar 10, 2011 10:53 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
landRoverNewbie
Nov 30, 2010 05:39 PM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
