Shaking at 35-60
Old Feb 16, 2023 | 07:37 AM
  #21
jastutte's Avatar
Originally Posted by greisinb
So I decided I’m going to have a go at doing this myself, this is, after all one of the reasons I have the D2. I watched the u joint video from the “Chris Fix” YouTube channel and it looked pretty straightforward, even more so since I have access to a 12 ton press at work. I was able to remove the questionable u joint and found that the bearing was completely dry, rusted and not a needle bearing to be found (see attached pic). What’s odd about this is that this is the bearing that had the zerk fitting for greasing. All the other bearings look fine. Anyway, my replacement joint just arrived at NAPA so here’s hoping it goes in just as easily as it came out.
glad you found the issue before the u-joint grenaded.
Old Feb 16, 2023 | 08:22 AM
  #22
XRAD's Avatar
make sure grease fitting is oriented in same location as original. And that you have marked all parts in relation to one another......otherwise....you will probably have to get your shaft balanced.....
Old Feb 16, 2023 | 11:12 AM
  #23
greisinb's Avatar
Yes, I was smart enough to mark all the parts before disassembly so I know they will all line up and balance out when I put it together. My new U-joint has 2 zerks on opposite sides rather than just one...hopefully that will balance out OK.
Red Flash
Discovery Sport
Feb 17, 2021 05:17 AM
nuclearw
Sep 27, 2013 09:08 AM
MvM
Aug 20, 2013 06:34 PM
worsethenu
Apr 23, 2013 10:16 AM
ollie
Jun 2, 2005 02:42 AM
