shelf, under driver's seat, on frame, what is it for?
Old 08-07-2013 | 09:13 AM
drowssap's Avatar
you could probably use the disco compressor but it would not last long it is not build for large volumes of air.
Old 08-07-2013 | 09:26 AM
acamato's Avatar
Originally Posted by bosshogt
The tank is filled with liquid Co2. Same thing that carbonates Coke. The tank when pressurized will run about at 160psi, so plenty of flow for power tools and you can fill all 4 of your tires up faster than your buddy with the Via Air compressor can fill 2 tires. The Powertank has a regulator on it like a scuba tank...so you can control the air pressure once the main valve is open.
CO2 tanks are around 1000 psi. The powershot regulator will reduce that pressure to 0-300 psi.
Old 08-07-2013 | 10:02 AM
dusty1's Avatar
Originally Posted by FlyingZebra34
I was thinking about putting an on board air compressor there for air in up the tires after wheeling
great minds.....that is what i did. made my sliders as tanks hooked the compressor to them from that mounted location. have since had problems with the little compressor. i used an old one that I had laying around. just can't do anything for free. but that is definitely, not a 1000lb co2 tank
Old 08-07-2013 | 10:08 AM
drowssap's Avatar
its a good idea using the sliders I used to use the tube bumper on my jeepster.
I throw a cheap high volume compressor from HF in the stock location, probably cost you $40.00
Old 08-07-2013 | 10:37 AM
dusty1's Avatar
oh sure, I see what's going on here. just another conspiracy to get me back in HF. $40 is probably more like $240. Like my $1000 winch
Old 08-07-2013 | 12:00 PM
drowssap's Avatar
Old 08-07-2013 | 12:13 PM
earlyrover's Avatar
"That's where the compressor sits if you have SLS." Bingo, that makes sense; I thought it had to be something like that. I don't have SLS, never had it, and don't want it, as it is just one more thing to maintain, and those rear air bag springs are not worth the trouble, in my opinion. Thanks for the information, guys!
Old 08-07-2013 | 04:01 PM
Chrisinhouston's Avatar
I mounted a small power amp there for my bass subwoofer that I put in the rear.
Old 08-08-2013 | 02:28 AM
Rover_Hokie's Avatar
It is for smuggling into Mexico!
Old 08-08-2013 | 05:36 AM
dgi 07's Avatar
I was waiting for that explanation. Took you long enough!
cogsley
08-13-2014 03:24 PM
RJJM
02-12-2014 07:29 AM
grandkodiak
02-03-2014 02:57 PM
1danger1
04-07-2013 03:54 PM
pilsner
08-30-2008 11:12 PM
Quick Reply: shelf, under driver's seat, on frame, what is it for?
