Shop unable to program remote w/o barcode??
Old Mar 30, 2009 | 09:13 AM
03DiscoSE's Avatar
Well working for a BMW/Mini dealer for the last 7 years and since the birth of the new Mini Cooper....I can tell you from experience that the barcode MUST remain intact or the key is useless from a remote standpoint. Unless something is different from the Valeo Land Rover key to the older-style Mini Valeo keys......but I just checked one and they look identical to me. The Mini has to be hooked up to the computer and the barcode entered off the tag before the car will accept the key. Like I said, I could be wrong about the Valeo Rover key but that's the way it is here at Mini.
Attached Thumbnails Shop unable to program remote w/o barcode??-0330090957.jpg   Shop unable to program remote w/o barcode??-0330090957a.jpg
Old Mar 30, 2009 | 09:30 AM
Thank you for clearing this up guys.
Old Mar 30, 2009 | 02:54 PM
roverguy7's Avatar
you do need the barcode in order for the bcu to know the key's code... however, the bar codes are based off of the serial number of the remote, and can be retreved using a simple cypher. he now has the code and hopefully he'll respond and let us all know if it worked
Old Sep 6, 2010 | 03:11 AM
heechen's Avatar
3rd Gear
Talking
Hi. roverguy7
I had 3 remote code 3f4343 312474 and 3f5b64
needs barcode.
please help me thank you.
Old Sep 6, 2010 | 07:06 AM
Bundu's Avatar
Banned
x2: the 6 digit code on the circuit board will give you what you need, the key can be reprogrammed from the 6 digit code.
Old Sep 6, 2010 | 08:13 AM
heechen's Avatar
3rd Gear
that 6 digit code can't programming remote.
must barcode entry remote.
Old Sep 6, 2010 | 09:25 AM
You do need the bar code, that is bottom line.
Old Mar 28, 2011 | 07:47 AM
s420vq's Avatar
Default Disco 2 fob programming
no. you do need the bar code. the remote works on a rolling codes, and the barcode is the key to that code... however, they didnt know what they were doing, because you can get that bar code... open up the remote like you were changing the battery and take out the circuit board, carefully. youll see a little sticker with a 6 digit code on it, pm me that code here and ill get you the bar code you need
Dave, I cannot seem to PM you. Can you please PM me with your email address?
Pieter
Old Oct 10, 2011 | 12:31 PM
sarahjayne's Avatar
Hi I have the same problem ie missing barcode, would you be able to help me out if I let you have the number? I am in the UK? Sarah
Old Nov 24, 2011 | 11:09 AM
mdzdisco04's Avatar
Hi roverguy7 was the dealer able to program the key with the bar code obtained from your remote?
if so could you please share what system did you use to conver the numbersfound in the remote into a barcode.
accessories4less
Jan 29, 2019 12:51 PM
en7rha
Dec 21, 2018 07:32 AM
cpn LR
Mar 1, 2014 04:05 PM
alanroberts50
Nov 6, 2009 10:24 AM
josemex
Aug 17, 2009 09:06 AM
