Shuts down while driving
Old Nov 27, 2012 | 07:40 PM
dandm211's Avatar
8th Gear
Default Shuts down while driving
I am the proud new owner of a 2003 Discovery HSE7. While driving, it will sputter then shut down, and usually restart. Today, I had the crankshaft position sensor replaced and while on the way home, it started doing the same thing, bit would not refire and stay running. When I lift the hood, I hear a buzzing sound coming from the main relay (R9). I pull the relay out and put back in and presto, it starts and runs.
What could be causing this? Cam sensor? Bad relay?
Old Nov 27, 2012 | 07:52 PM
Maybe relay. The ECU grounds it to activate. Bad connection at ECU?
Old Nov 27, 2012 | 07:55 PM
Shade Tree's Avatar
I vote for bad relay. Should be another one you can swap around.
Old Dec 4, 2012 | 11:10 AM
dandm211's Avatar
8th Gear
Default Update
Well, this has been a process.
1. Replaced the Cam Sensor - still had the issue
2. Replaced the relay - still had the issue.
3. Replacing the fuse panel under the hood, looked as if a small fire happened under the panel shorting out the main relay.
Will update when complete.
Old Dec 5, 2012 | 04:09 PM
dandm211's Avatar
8th Gear
Ended up being a short under the fuse box causing all of the problem.
I hope I can enjoy my Disco HSE7 now.
lmcgrew79
Oct 5, 2013 07:34 AM
klh113
Mar 28, 2011 02:08 PM
bladerover
Oct 6, 2009 08:11 PM
wslawal
Sep 18, 2006 10:12 PM
ranger
Jun 11, 2006 04:29 PM
