Shuttle Valve Question
Old Aug 30, 2007 | 12:33 AM
Kraftyz51's Avatar
Default Shuttle Valve Question
The three amigos showed up and I took the rover into an independant shop. They said I was triggering a Shuttle Valve code. Instead of replacing it he reco'd a shuttle valve kit for 90$. He is charging me about 300$ to do the job (part included). What is this part he is replacing and is it a 3 hour job? What is a shuttle valve?
Thanks,
Old Aug 30, 2007 | 06:34 AM
tads's Avatar
Default RE: Shuttle Valve Question
If you've got a good connection internet wise you'll appreciate the pictures and explanation of this thread:
https://landroverforums.com/m_35119/tm.htm
Hope it helps!
Old Aug 30, 2007 | 07:49 AM
The replacement of the shuttle valve may or may not fix the problem, it is a 50/50 roll of the dice. If it fixes the problem, the $300 spent was a great deal when you consider a replace unit is into the $2500 range.
The new shuttle valve assembly has been up dated to take care of some old ABS issues that have been showing up.
bosshogt
Feb 2, 2012 06:52 PM
aarongregor
Nov 14, 2011 08:31 PM
majrmike
Oct 9, 2007 03:13 PM
Different Drummer
Aug 7, 2006 09:28 AM
rovernbama
May 9, 2006 11:12 PM
