Significant Leak in front Left of Disco
Old Jul 11, 2018 | 03:23 PM
  #21
flyingmada's Avatar
And what store I can buy a hose that would work?
Old Jul 11, 2018 | 03:47 PM
  #22
shanechevelle's Avatar
If the connection on the cooler is moving you ruined your cooler. Those pipes cannot move or the seal breaks.
I took a cutoff wheel and cut the hose parts off the aluminum tube. You have to be VERY CAREFUL as the tube has a raised area that will leak if you cut into it.
Once the hose parts are off, clean the pipe. Find some hydraulic line and slide it onto the pipe. Find the best hose clamps you can find and tighten it up. You dont need the factory hoses. You dont need the factory coupler.
I bought really rigid hose and added enough so even if the pressure were to try and push the hose off the pipe it cannot.
Everyone's lines are getting old. Mine blew off while my wife was driving it and the transmission emptied out in a couple seconds.
Dont forget to add fluid to your transmission too. It's probably low and you'll do damage.
Old Jul 12, 2018 | 05:13 PM
  #23
TaylorCadence's Avatar
Originally Posted by flyingmada
anyone know the size of these hoses? I’m just going to buy a high temp and worm clamp it
I believe it’s 5/8 inner diameter.. don’t quote me it’s been a while since I did the job
NewToTheTwo
Sep 25, 2019 09:34 AM
blwngsket
Apr 17, 2016 09:43 AM
khandrh
Sep 25, 2009 09:57 AM
aBs0lut30
Jul 1, 2008 08:24 AM
willlane
Nov 10, 2007 07:33 PM
