Slight "clunk" when turning
Old Mar 9, 2009 | 06:07 PM
humroot's Avatar
Default Slight "clunk" when turning
Hi Guys,
I noticed the other day that when I turn I get a slight clunk. It sound like it is coming from the passenger side front. I checked the shock and spring and they seem fine. You can't really feel it, just hear it, and it only happens once while turning. It seems to happen more when I turn left.
Any ideas?
Thanks,
Old Mar 9, 2009 | 06:11 PM
tiredone's Avatar
Check to see if you have a torn CV boot.
Old Mar 9, 2009 | 06:17 PM
Crawl under the truck and start re torquing everything that has a bolt/nut including the radius arms.
Old Mar 9, 2009 | 06:22 PM
humroot's Avatar
Thanks for the suggestion. Just checked them and they look fine. No tears.
Old Mar 11, 2014 | 03:42 PM
humroot's Avatar
Can't believe it's been almost 5 years to the day since I first posted this and today I found the problem. Yea, I have been very accepting of the clunk I could never find. And it's not in the front, it's in the back.
Anyway, I was looking at similar posts today and someone posted about testing with the ACE fuse pulled. So I pulled the fuse and no clunk. Went under the car and started pulling on all the ACE stuff. Now, I have done this before, but only in the front. Moving on to the back, first thing I grab is the anti sway (listed as torsion/anti sway in RAVE) and the whole anti sway bar moves about 1/4 inch up and down on both sides. So there you have it, the anti sway links in the rear are the problem.
Figured I would share the answer since it is finally solved. Apologies for bringing back a very old thread!
Now on to the oil leaks....
jycsalas
May 23, 2019 03:02 PM
DiscoEiner
Sep 21, 2014 02:37 PM
H Hill
Mar 30, 2012 07:32 PM
kenk
Aug 24, 2010 03:31 AM
DiscoMike2003
Nov 13, 2008 04:57 PM
