Slight coolant leak
Old Feb 10, 2019 | 11:51 AM
  #31
Daytoman's Avatar
Ok I confirmed yesterday that its 99% sure coming from the spot in the picture. Looks like this is common. Obviously, I’m going to need to replace that gasket. It will get a new water pump as well. Gonna have to be a Spring project.
I put wrench on the three bolts within the red circle in that pic. Got some decent movement in the one in the center, where the leak is actually coming from, and the leak stopped over night. It is n longer wet around the area as well. So I hope this is a temporary fix and I’m going to watch it until Spring.
I also found that this has just started on my 03. Tightened down the same 3 bolts and leak immediately stopped.
Old Feb 10, 2019 | 01:38 PM
  #32
Best4x4's Avatar
A few bolts go into the water jacket so tightening them usually can fix a leak in that area. If it leaks again = replace gasket.
Old Feb 10, 2019 | 01:52 PM
  #33
Daytoman's Avatar
Thanks! I found the exact same thing on the 03 while I was underneath it yesterday. It was a much slower leak, the gasket is of a different material and it looks a lot “healthier” than the one on my 04. So we’ll see how that one holds up.
Old Feb 11, 2019 | 05:04 AM
  #34
shanechevelle's Avatar
If it leaks again, remove bolts, wrap with pipe tape, reinstall.
Old Feb 11, 2019 | 08:23 AM
  #35
Daytoman's Avatar
Got it.
Dogfan
May 14, 2013 05:01 PM
toofaroffroad
Mar 30, 2012 11:15 AM
jlweaver1
Dec 20, 2011 04:42 PM
97DISCOIDAHO
Mar 19, 2007 05:06 PM
