Question for those with home car lift or quick jack
Old Feb 10, 2019 | 09:55 AM
Gonow's Avatar
Default Question for those with home car lift or quick jack
I’ve been thinking about getting a Quickjack and when I looked under the truck to take some measurements I noticed that the ladder frame rails are some distance away from the rocker panels. Access to them is also sometimes blocked by the front/rear radius arms. Not only that, but the various brackets and mounting points protrude downward from the frame rail.
For those of you with a car lift or quick jack, where do you lift from? The manual says to use axels or frame, but I imagine the radius arms get in the way no? Is it OK to lift by the radius arms? I noticed that being done in some Atlantic British videos.
Old Feb 10, 2019 | 10:03 AM
Saturnine's Avatar
I jack mine up via the shock mounting points in the axles and then jack stands in the notch of the radious app
Old Feb 10, 2019 | 04:14 PM
escott16's Avatar
Old Feb 10, 2019 | 10:59 PM
Gonow's Avatar
Thank you! Btw your undercarriage is immaculate. 👍
Old Feb 11, 2019 | 11:21 AM
myD2HSE's Avatar
I don't at the moment have an undercarriage view showing the lift points, but I am using the point where the control arms attach to the frame. Not sure what lift eScott has but I like his high lift adapter more so than what I have on my TwinBusch lift. The collar under his pad looks sturdy.
Old Feb 11, 2019 | 01:08 PM
Llamasayswhat's Avatar
The problem is if you use the frame or even the suspension points, it puts the lift arms pretty far in towards the center of the car, and it is not very stable.
The best support spot as shown in the photos from escott16, is the point where the body and frame bolt together. You need a block of wood or rubber pads to lift there though, and it takes a bit of feel/getting used to as the front one has a funky angle as the bracket goes back into the center of the car.
Old Feb 11, 2019 | 01:17 PM
escott16's Avatar
Mine is extreamly stable I’ve jumped up into the car , shook it , it’s not going anywhere , and I use wood just so I don’t wear out the rubber plates on my lift
Old Feb 11, 2019 | 03:03 PM
myD2HSE's Avatar
Originally Posted by Llamasayswhat
The problem is if you use the frame or even the suspension points, it puts the lift arms pretty far in towards the center of the car, and it is not very stable..
RE stability, I use two 20 ton jack stands. One in the front another in the rear opposite sides. It has been pretty solid for me. While I see where eScott jacks it up, I would not have thought to lift there initially as I would hate to have the body panel fold due to the trucks weight.
Old Feb 11, 2019 | 03:04 PM
escott16's Avatar
No damages , I’ve had it on a lift probably 10+ times sometimes days at a time
Old Feb 11, 2019 | 05:23 PM
The question was about using a lift, not jacks and stands. Jacks and stands would be fine there, but the nature of lifts with the single mount point for the lift arms makes it sketchy and unstable at best unless you use the outer points at the body mount like escott uses.
We lift all the discos in our shop at that point
bcolins
Jan 14, 2017 10:22 PM
cybercop
Sep 11, 2015 07:24 AM
Micko
May 5, 2015 11:20 PM
dusty1
Jan 16, 2014 09:49 AM
echomike
Mar 1, 2011 11:16 PM
