Smell coolant but no leaks!!!
Old May 13, 2013 | 10:42 PM
Dogfan's Avatar
Default Smell coolant but no leaks!!!
I am confused! I smell coolant inside my 2003 HSE7 Disco but can't find a leak anywhere! I have checked the coolant level and it has dropped some over the last month but very little. The heads and gaskets are new so no leaks there. Could this be a small leak from the heater core o-rings?
Thanks in advance!
Old May 13, 2013 | 11:46 PM
Bryan H's Avatar
Check the throttle body heater hoses at the TB end and also where one of them goes into the intake. I just noticed a small leak there on mine (I just replaced the crappy factory clamp with a worm style. Hopefully that fixes my problem....which sounds just like your problem.
Old May 14, 2013 | 12:15 AM
Mojigglins's Avatar
X2 on the throttle body heater hose. Replaced the hose clamps. No more coolant smell.
Old May 14, 2013 | 06:08 AM
drowssap's Avatar
rent or borrow a cooling system pressure tester or your just wasting your time
Old May 14, 2013 | 04:49 PM
Dogfan's Avatar
Would you attach the pressure tester to the coolant reservoir?
Old May 14, 2013 | 05:01 PM
Yes, and pump up to 15 PSI. There was a write of one guy you used an old coolant cap with an air chuck fitted. P_arts stores rent them, but check to be sure the adapter fits your coolant jug.
Broken08
Sep 28, 2023 07:07 PM
Spencerfitch
Sep 27, 2020 12:17 PM
FlyingZebra34
Apr 22, 2013 12:07 AM
discoboy
Dec 20, 2012 02:24 AM
foreverdisco
Dec 4, 2008 06:36 PM
