Slight engine ticking...
Old Oct 11, 2011 | 03:39 PM
anbran's Avatar
Haven't put a gauge on it yet...
The oil filter is a Land Rover brand that was new (plus oil) when I bought the truck from a LR dealer 2 months ago.
Old Oct 11, 2011 | 04:10 PM
atancreti's Avatar
You need the Mobil one 301 filter. It's very large so you get increased flow.
Old Oct 11, 2011 | 10:10 PM
anbran's Avatar
Are you serious? The Land Rover filter is restrictive?! That's the first I've heard of that. Maybe that's the answer for so many of the "ticking's" that people have...!
Old Oct 11, 2011 | 10:45 PM
Don't think we will be that lucky. The Mobil1 filter is highly rated, and sports a 10 micron filter. This gets really small stuff out of the oil. I happen to have an older truck with 175 K, and I run a WIX 51459, which is even larger and you get another 1/2 quart or more oil capacity. But this WIX (not all WIX) operates at 35 micron.
See attached for RAVE info on the oil system, and explanation of the hydraulic lifters. Sometimes these have to build up pressure and may make that noise until warmed up lightly But that is not the only thing that can make noise....
To unstick lifters, some use a flush of ATF or other solvent, then change oil. Some use a quart of very thin oil, like Marvel Mystery Oil. Some use a solvent, like SeaFoam, which can dissolve some sludge while you drive. But just as much benefit usually happens when you change to a diesel rated oil (like Rotella) and change often. The xtra cleaning chemicals help get rid of the gunk.
File Type: pdf
Old Oct 11, 2011 | 11:09 PM
atancreti's Avatar
Probably won't get that lucky with just the filter. But just something to look into in the future. Have you checked the psi numbers yet?
Old Jul 17, 2018 | 05:13 PM
anbran's Avatar
...By the way...The ticking noise was a cracked exhaust manilfold! After a few moments, it gets quiet. The heat expands and the crack seals!
Old Jul 17, 2018 | 06:53 PM
The Deputy's Avatar
The "cliffhanger" finally comes to an end. Man, talk about building to a climax...making us wait 7 years...lol.
Brian.
Old Jul 20, 2018 | 12:35 PM
anbran's Avatar
Haha...so sorry. I had forgotten about it and just went on with life. I came back to the site recently and saw my old posts. Noticed the "cliffhanger"...thought I'd better say something!!
Nikkiwi
Feb 20, 2013 06:32 PM
Kappa Man
Feb 14, 2012 08:13 AM
hhalimi
Feb 8, 2012 11:32 AM
fiorano
Jan 21, 2012 04:19 AM
handsome rob
Jun 19, 2007 11:26 PM
