Slight rough idle...where I do I look next?
Old Sep 14, 2023 | 08:15 PM
  #21
mln01's Avatar
Hey, dgtrawick5, if your truck is having a slight rough idle like the title of this thread, is the Service Engine Soon light on? If so, get the diagnostic trouble codes read and then start a new thread to let us know what you found.
This community loves to help, but we need good information to do that. Without diagnostic codes you (we) are just guessing, throwing away parts, money and time.
Old Nov 17, 2023 | 11:47 AM
  #22
dgtrawick5's Avatar
Default Rough idle
Hey, so the recurring code is P0441. I’ve put in a new Bosch purge and it is functioning properly according to my mechanic. Replaced leak detection pump with new because he said it wasn’t functioning. Now beginning to think it’s a clogged charcoal canister because I do have trouble occasionally having the gas pump cut off on me while filling. Any thoughts that clogged charcoal canister could cause semi-rough idle?
Old Nov 17, 2023 | 01:22 PM
  #23
adolfojbonilla's Avatar
Originally Posted by lipadj46
Check your fan blades and make sure nothing is missing. Otherwise I never was able to get a completely smooth idle and just accepted that tiny bit of roughness. No one else seemed to notice though.
...thanks for the tip, I'm gonna look into this; my 2K2-DISCO-S2-SE has a rough idle along with a misfire code from cyl 5 that I'm through the swapping-parts phase to try and rule out (already swapped plug, wire is next), but my fan does has some blades messed up and isn't in the best of shapes -it was already in my list of parts-to-replace.
Old Nov 17, 2023 | 05:04 PM
  #24
Harvlr's Avatar
detracts, I have no idea what your slow to refuel issue is, but this was mine
https://landroverforums.com/forum/di...-111773/page2/
Old Nov 17, 2023 | 05:06 PM
  #25
Harvlr's Avatar
Sorry dgtrawick5, my spell check changed your name to detracts
dillhole
Feb 20, 2020 02:30 PM
agthird
Sep 4, 2010 09:44 AM
Spencerfitch
Jun 8, 2010 12:41 AM
Disconoobie
Oct 19, 2009 04:26 PM
byebyeH2
Oct 9, 2008 10:54 PM
