Small Modification Write Ups + Index of Mods (Alex_M)
#81
[QUOTE=Alex_M;546874]Whooo, pretties pictures in a write up ever! I'm going to try to start using my nice DSLR for these write ups to add a little quality and be a little nicer on the eyes.
Ok, so this one is pretty simple. First, you need two Spectre 3992 Oil Breather Filters.
Don't you want the vacuum to pull the oil vapor away from the engine to be burnt and escape your engine? I never understood the reasoning for putting a filter on unless it is a super high RPM or boosted performance engine where extreme pressure are getting generated within the engine.
#83
Truth be told, it doesn't make a lot of difference either way. The reason I did mine this way was because it was easier than replacing the broken oil separators. It doesn't really hurt or help anything to run it the other way or this way.
[QUOTE=sickws6;561855]
#84
[QUOTE=Alex_M;561870]Truth be told, it doesn't make a lot of difference either way. The reason I did mine this way was because it was easier than replacing the broken oil separators. It doesn't really hurt or help anything to run it the other way or this way.
It helped me. My throttle plate or butterfly or whatever you want to call it is clean as a whistle. It got gunky before.
And yes I check it occasionally (usually due to some engine malfunction or a semi annual engine swap).
#85
#87
Actually, mine has done the same. I believe its because its right on the valve cover. I'm going to attempt to run a line to raise it before too long, but in the mean time its not hurting anything other than the little bit of oil leaking out. Will update when I get to that.
