So I did a thing
So I did a thing
Well you see it all started when I was replacing the fuel pump. Noticed some rust. Then one thing led to another and now she's stripped down. Going to grind out the rust and re paint it with POR15 then install a ton of dynamat. Also wasted a chunk of change on eBay buying replacement plastic bits. Decided to fix the interior up correctly.
The following 2 users liked this post by FlyingZebra34:
CollieRover (06-04-2019),
Glatt (06-22-2019)
Dont use Dynamat unless you just have money to burn.
its just an over priced named brand
Something like this is just as good and cheaper -
Also know that these type products - Dynamat included - are vibration dampening only, not sound deadening - you'll want to layer a sound deadener on top if thats what you're looking for.
Vibration dampening can be sparcely placed while the sound dampening should cover completely.
The following 2 users liked this post by NewToTheTwo:
JUKE179r (06-21-2019)
