Some Maintenance done...
Old Dec 26, 2008 | 08:55 PM
tomfraser's Avatar
Default Some Maintenance done...
I changed my wires to magnacores (gonna do plugs tommorow) (my old wires were very stiff)
Changed diff oils, this time added lucas gear oil supplement
Got "EMISSIONS MAINTENANCE REMINDER" relay and installed it (was missing altogether previously)
Now when I drive, I do not notice any gains in power or acceleration in the lower end, but around 3000 RPMs my car is much quicker at accelerating.
was this the magnacores?
If so I can't wait till I get new plugs... going with +4s, not sure if the iridiums are worth it
Old Dec 26, 2008 | 09:03 PM
sloppyjoe's Avatar
Default RE: Some Maintenance done...
i have run +4's (briefly) in a vehicle.
i run iridium's in all of my vehicles. when i do the plugs in the rover it will be to iridium's. in my experience there is no question on the swap to iridium plugs.
they are worth it,,,
Old Dec 26, 2008 | 09:04 PM
tomfraser's Avatar
i'll be giving them a shot then... same price as they are on special!
Old Dec 26, 2008 | 09:09 PM
sloppyjoe's Avatar
you will enjoy
Old Dec 26, 2008 | 09:11 PM
Yes iriduims are worth the extra money.
Old Dec 26, 2008 | 09:20 PM
tomfraser's Avatar
Another thing i've noticed that has been happening recently is when I am starting my car sometimes it starts after 1 or 2 seconds
Other times It begins to turn then all the sudden all I can hear is the starter spinning, so stop turning the key and I hear the starter still turning until it all the sudden stops, then it starts as normal
can the starter slip or lose connection to the engine somehow? does this sound like any specific problem or do I need to describe it better?
Old Dec 26, 2008 | 09:21 PM
sloppyjoe's Avatar
ORIGINAL: Spike555
ducatis run like they on running on coal,,
with iridium plugs,,, its runs like its on more coal HAHAHHAHA
Old Dec 26, 2008 | 09:23 PM
sloppyjoe's Avatar
ORIGINAL: tomfraser
could be the flywheel missing teeth or teeth wearing out. or the starter solenoid is crapping out
Old Dec 26, 2008 | 09:24 PM
Your starter is going bad.
When you turn the key to start there is a shaft inside the starter with a gear on it, that gear kicks out and engages the teeth on the flywheel and then the high touqre starter motor turns the engine over fast enough for it to start running on its own.
One of the signs of a starter going bad is this gear not engaging the flywheel.
Old Dec 26, 2008 | 09:28 PM
sloppyjoe's Avatar
ORIGINAL: Spike555
say it!!!
solenoid,,,, joe wins!!!
